I need to copy a DVD over 2 hours using a MAC. I have "DVD backup" as well as "Toast Titanium 5.2.1" Is it possible to do this? Is there any other software out there like Pinnacle's Instant Copy for PC that allows you to fit 8 gb on a 4 gb DVD-R?
thanks,
john
Thanks,
John -
yea, you need DVD2one which you can get at www.dvd2one.com
its a program you need to buy and its well worth every penny
once you get it theres a how to at many of our sites (including mine)
get the newbies guide TODAY from me, because my site will be down after 12AM today for a while.
otherwise, TGPO has a great site with a tutorial as well
its really easy. -
Another option, if you wanted, would be to split the DVD onto 2 DVD-Rs. For that you can use Discomvobulator.
a three hour movie looks really decent in movie only mode with the constant video mode instead of variable.
dont do diskcopy, it will look pretty crappy.
So I'm Making a Power Hour DVD...
By Jskot311 in forum Newbie / General discussionsReplies: 2Last Post: 1st Apr 2011, 14:35 -
Cant copy Rush Hour 2
By websurfer in forum DVD RippingReplies: 2Last Post: 9th Aug 2009, 21:45 -
DVD Power Hour Project Help.
By GlockMasta in forum Authoring (DVD)Replies: 3Last Post: 1st May 2009, 07:23 -
why convert a MKV to DVD format took more than an hour ?
By c1steady in forum Video ConversionReplies: 2Last Post: 1st Apr 2009, 20:34 -
4 half hour eps on one dvd?
By motleycool in forum Newbie / General discussionsReplies: 4Last Post: 4th Jun 2007, 00:18
