I am fairly new to morphing with Elastic Reality, and maybe there is someone out there that knows the answer to my problem.
When morphing faces at about 45 degrees or greater, the Nose overlaps part of the face, which cases edge overlaping. How would you go about outlining the vectors to prevent this?
Below is an example where edge overlapping would occur.
http://www.escape.ca/~guiboche/rlr1.jpg
http://www.escape.ca/~guiboche/rlr2.jpg
http://www.escape.ca/~guiboche/rlr3.jpg
How would I make it so the face would remain below the nose during the morph without causing it to smear the way it is.
Thanks for your time.
Guiboche
well you can try to morph from B to A. Or you can take that mid problematic frame and fix it with any image prog and morph between the three. Just a suggestion. Tell me if it works.
What is a good program for Morphing video
By jbandy1 in forum Newbie / General discussionsReplies: 8Last Post: 22nd Apr 2011, 11:58 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
