I'm hoping someone can give me suggestion on which player to get. I have a Sony NS300 now, that I want to upgrade. Reasons being, it won't play VCD's unless they are on a certain brand of cdrw media and that's only 650mb. Also, it won't play SVCD's unless they are on that certain brand of cdrw media with a vcd header trick performed on it. It's a pain honestly.
I've been very happy with Sony and Panasonic products. I was looking at the Sony 325 single player and the Sony 665 changer, Panasonic 65 changer..
I want it to be able to to play vcd's, svcd's, dvd+-r/rw would be nice for the future. Progressive scan isn't important to me now, I don't have an HDTV.
Anyone have any experiences with the above players I mentioned, any problems playing vcds, svcds, how about non-standard svcds that stray a little above the normal bitrate?
Thank You
I have a Sony DVP-NC655P changer which is probable a cousin to the 665.
Mine plays VCD and SVCD (no header trick needed) fine and I have used several different media brands (R & RW) with no problems.
Plays -R and -RW fine (I don't have a + burner) and I have used several brands there too.
I have pretty much done standard bitrates so I can't help much for the hi rates for SVCD.
The 655 is progressive but my Mitsubishi is 1080i so I can't use the progressive feature.
Very pleased with this player. My old Sony couldn't play cd-r, only rw and couldn't play dvd-rw, only r and no svcd (unless using header trick).
jbcandkcI'm just sitting here watching the wheels go round and round.
-John Lennon -
I always find it amazing that people will limit themselves to a few brands (10%) of the options right off the bat. When looking for a new device, look for the best of all of the brands, not just the best of two.
Do all Sony & Panasonic Bluray players recognize AVCHD files?
By jbitakis in forum DVD & Blu-ray PlayersReplies: 5Last Post: 27th Nov 2011, 04:19 -
HDD Media Players - Any recommendations?
By DVantrease in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th May 2008, 12:11 -
Sony DVP S360 DVD players - No DISC ERROR
By parmar in forum DVD & Blu-ray PlayersReplies: 16Last Post: 14th Dec 2007, 10:44 -
Any recommendations for players that will play dvdr dual layer discs?
By vinland in forum DVD & Blu-ray PlayersReplies: 9Last Post: 22nd Oct 2007, 04:02 -
UK: Need Recommendations of DVD Recorders (to replace panasonic!)
By webstar in forum DVD & Blu-ray RecordersReplies: 7Last Post: 23rd Jul 2007, 19:05
