  1. I'm capturing my DV from my Camcorder into my pc with Pinnacle Studio 7. What I want to know...if I take the video I captured and then select create MPEG and set it to 720 x 480 with 48 khz on the audio, can I burn that straight to a dvd?
    When I click and drag the clips from the captured video to the bottom screen, is that creating menu or chapter points?
    If this will not work, then what is the best way to get my video off my camcoder and burned onto dvd?
    Thanks!
  2. I'm a studio 8 user, but I' sure you can find out here at the Pinnacle Studio 7 forum board :
    http://webboard.pinnaclesys.com/read_forums.asp?WebboardID=1&SectionID=58&ProductID=42...DocTypesID=123
    Geronimo
  3. Thanks...will look at it...I've got Studio 8, just haven't had time to install it
    DarkCyber
  4. Well, the pinnacle boards didn't seem to be any help. I posted in there, but never even could find my post..so can't get an answer if no one can see it
    Anyway, I answered my own question. I just created an mpeg file inside Pinnacle and that will burn to a dvd using DVD-lab.
    DarkCyber
