The issue I have is that after taking all of the subtitles out except English the resulting backup DVDr will play fine in the set-top but the subtitles are on by default.
In the past, I have used DVD2one to do these backups. But to solve this subtitle always on issue, I used IfoEdit to insert the pre-command and put the subpicture to 0. The backups would then work fine with having the subtitles off by default.
I thought I would try CloneDVD and it does the same thing.
Is there anyway to solve this issue with out doing the manual edit? CloneDVD outputs in ISO format and not file format like DVD2one. I haven't been able to edit the files like I normally do.
Help? Answers? Bueller?
Results 1 to 1 of 1
ConvertXtoDVD subtitle issue.
By Randwill in forum SubtitleReplies: 3Last Post: 7th Sep 2011, 10:01 -
subtitle issue when re-encoding..
By tsh in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2011, 00:26 -
Subtitle issue
By Mrsash in forum Newbie / General discussionsReplies: 2Last Post: 2nd Oct 2010, 19:43 -
Subtitle issue
By eppingwest in forum Authoring (Blu-ray)Replies: 0Last Post: 8th Feb 2009, 12:35 -
Subtitle issue with DVDAuthorGUI
By GangstaRap in forum Authoring (DVD)Replies: 1Last Post: 11th Feb 2008, 06:37
