Hi
Sorry if this is a n00b question, but i did search ths forums and guides..... didn't find a solution i could use
I have a 720x384 divx file, is there a way i can make it a 4:3 aspect ratio for my TV (by adding black bars maybe) w/o losing the correct height/width??
Can i make it 720x480? Even straight to a 320x240 mpeg??
Thanx in advance for any help...
----- are ther n e programs i could use?? maybe mainconcept (i hav it) or TMPGEnc??![]()
Use DVD2SVCD with TMPGEnc encoder. There is an option to encode as 4:3 with black bars added. I have done this before and it works fine.
The default will make a 480X480 SVCD mpeg, but the advanced settings let you convert to 720X480 (DVD) or half D1 352X480 (DVD or CVD) Here is a guide
https://www.videohelp.com/forum/userguides/111846.php
One thing though, if the DivX has any errors in it the conversion will almost certainly fail..... In that case you will need to first convert the divx avi to to a new format. What I do is convert to an avi with Huffyuv video and uncompressed wav audio. The file size will be huge, like 30+GB so you would need a big hard drive. The reson I use huffuv is so there is no quality loss befor the mpeg encode. I use Virtualdub for this -
Originally Posted by thayne
i m going to try it again, i ll tell u the results,
thanx thayne for ur help
if n e 1 esle knows othere solutions for corredt resolution keeping aspect ratio [with blak bars = 4:3], plz tell me
Aspect ratio for SD Widescreen on YouTube
By matthewjohn23 in forum Video ConversionReplies: 9Last Post: 1st Nov 2010, 18:14 -
Widescreen aspect problem converting avi to dvd
By spiritgumm in forum Video ConversionReplies: 8Last Post: 10th Apr 2010, 13:14 -
Converting from Mini DV - Problem with Aspect Ratio PAL Widescreen
By Videonisse in forum Capturing and VCRReplies: 9Last Post: 30th Jun 2009, 17:01 -
How would I combine these avis into widescreen or TV aspect ratio?
By Han Solo1 in forum Newbie / General discussionsReplies: 9Last Post: 6th Mar 2009, 16:48 -
Watching AVIs in normal aspect ratio on a widescreen TV
By fiiido in forum Newbie / General discussionsReplies: 6Last Post: 9th Aug 2007, 07:05
