I've used the Dr DivX demo program to convert a few movies to DivX format, is there a way to re-convert the smaller DivX-sized files back to DVD format, so one can put several movies on a DVD+/- R ??[/b]
Anything is possible. However, the quality won't be as good. And to fit multiple movies you will have to reduce the quality even further.
Google is your Friend -
go look in the guides section there is all kinds of sweet stuff
If time is money then I am traveling back in time. -
The answer is yes. However, the image will never be as good as the original and the worse your divx image is, the crappier the picture will be.
I would recommend getting Gspot and a bitrate calculator to help you out with the correct bitrate to use. Experiment as well with short clips to find out what the limit for bitrate encoding you should use. When using Divx material, there reaches a point where more bitrate doesn't give you anything....sort of like driving a race car in a 30mph zone...all the power of the engine and you're stuck doing 30.
for encoding multiple movies, multipass VBR will give you a better image for space, but the encoding takes a lot longer.
hope this helps
Widescreen back to 4:3 format
By Acemon in forum Video ConversionReplies: 2Last Post: 22nd Feb 2011, 22:29 -
DVD to Divx and Back
By willgonz in forum ffmpegX general discussionReplies: 5Last Post: 24th Aug 2010, 12:25 -
Converting from DVD to format to play back using media share/directv dvr
By Nosey249 in forum Video ConversionReplies: 0Last Post: 24th Feb 2010, 09:35 -
Hi8/Video8 to DVD...to editable format...back to a DVD with a menu!
By lornarose in forum Authoring (DVD)Replies: 14Last Post: 8th Nov 2008, 16:03 -
Will HD-DVD make a come back like DIVX?
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2008, 21:34
