  1. im trying to fing a way of to make dvds that will play on my peas of .... NAD512 dvd player
    and i have tryed using the plus version, but my dvd just dont wanna deal with off standart dvds, here is the deal if i use mpg audio, it goes out of synch, ac3 just playes 2 sec and stops.
    2 pass dont help, the problem is the dvd, i tryed lots of different files, but no go
    so here is what i would like to try, if i could give SVCD2DVDMPG+ standart 720X480 mpg2 video, and i would convert it to ac3 to se iif that would work
    regards easy=)
  2. Did you try this guide to create sync audio: https://www.videohelp.com/forum/viewtopic.php?p=545253#545253
    Greatings,
    Yf
  3. i tryed it, but its my dvd=(
    well i could have checked the compatibility base before byeing it=)
    it dont play svcd, my conclution is that the mpg audio decoder is just soo poor thay decidet to leve svcd out, just a teory=)
    i had a realy cheap denver dvd player before that played everything,
    but at least it plays dvd+-R/RW movies within specs,
    regards easy=)
