Results 1 to 14 of 14
  1. Member Treebeard's Avatar
    Aug 2002
    Okay I pulled a no brainer and lost some emails that I need to recover, here is what happened.
    After installing XP Pro (fresh) I logged on as Administrator, which is the only default option. I installed office 2000, setup my outlook, downloaded my emails, installed some other stuff, set up another user as computer administrator, and a couple of limited users. rebooted, Administrator was no longer and option for logging in, only the 3 users I created 1 being a admin user. logged on as the admin user i created and outlook had to be setup again but now the emails were already downloaded w/ the administrator login originally and I cant login as that user anymore to get them back. Where did the default Administrator user go? I didnt remove him, just gone. Next time I need to think b/4 i start just setting up stuff
    Anybody got some ideas.
  2. Member Treebeard's Avatar
    Aug 2002
    Nobody knows huh? Well I guess we just chalk up another mark against PC's then.
    I did try to add a user call Administrator- it told me there was already a user with that name- then y the hell cant i see it
    Windows YOU SUCK!!!!
    okay i feel a little better
  3. can you see the administrator in my computer/properties/user profiles?
    Originally Posted by jagabo
  4. Member Treebeard's Avatar
    Aug 2002
    No its not there. Thats what I'm saying its gone from the profiles section and its not on the main login screen, but It wont allow me to add a user called administrator b/c that name already exists it says. Im not a novice computer user but this is ticking me off.
  5. I wasn't enferring that you were a novice computer user. just trying to cover the bases
    After setting up the comp. did you make it join a domain or anything like that?
    Do you see the profile under doucuments and settings?
    Did you rename the admin account?
    Did you do a search for the pst files?
    Did you do a search for the ost file?
  6. Member Treebeard's Avatar
    Aug 2002
    1) no
    2) no
    3) no
    4) yes
    5) no
  7. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    And truth, shall set you free!
  8. Member Treebeard's Avatar
    Aug 2002
    thanks, I may be free now, but still without my emails.
  9. If you do not see the admin profile under documents and settings and can not find the pst file, your hosed. Were you connecting to an Exchange server or to a pop3 server? Sounds like a pop3 server. The exchange server will still have all the emails, but the pop server will not (unless you specify to leave messages on the server)
  10. Member Treebeard's Avatar
    Aug 2002
    yes it is a pop3 server & I do have outlook set to delete messages on server after getting them. I did a search on the whole HD for any pst files and couldnt find it. oh well, I quit
  11. On windows XP the administrator always exists (even doo you do not see it)
    just try logging on using adm... and the password you assigned to it and voila :
    next time THINK before you ACT (or REACT 8) )
  12. Member Treebeard's Avatar
    Aug 2002
    what way is there to log in besides the main login screen? I realize that "a" admin account always exists but I need the admin that was there on first boot called Administrator.
  13. Originally Posted by DoleBole
    Problem is, if the profile is missing from the system (in this case) then logging in as Administrator will rebuild it from the default user profile and the email will still be missing.
  14. You could try removing all the log on accounts you created, you should then have no option but to log on as administrator.
