I've been trying to encode a few movies, but the audio and video wind up being de-synched.
On one (DivX3 PAL), the audio is faster than the video. Do I cut the framerate?
On the other, the audio is deleted altogether. How do I fix this?
Thanks.
Well, you start out by telling the gurus exactly what programs you use and what you did. Then they can begin to help you.
Hello. -
Soitanly!
I used TMPGEnc to try and encode it (as it says in Sefy's guide), doing nothing to it before-hand, but when I was screening the finished MPEG before burning it to VCD, I noticed there was a lag in video when compared to the audio. I checked back in the source AVI at the same time, and found the video froze while the audio kept going.
I just used DivFix to mend these errors, but it deleted the part right out of the video! Is there any way to save it? -
In Virtual Dub, did you select Video-->Scan video stream for errors?
Hello.
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 09:02 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 12:12 -
Syncing spearate audio/video: Better to stretch/shrink video than audio?
By stantheman1976 in forum EditingReplies: 15Last Post: 16th Jan 2008, 05:14 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 01:23
