i'm very new at burning vcds so plz don't get pissed if i ask stupid questions..
anyways, i have a movie that is extracted in vcd format... the files i get are cdi, ext, mpegav, segment, and vcd w/ files inside of them...
what program do i use to burn these onto cd and then play in my dvd player??? i tried just burning it w/ easy cd creator as a data cd but that doesn't work cuz my dvd player doesn't reconize it...
any help would be appreciated...
Viper.
First you check in the DVD Player compatibility list on this website, if your DVD player will play VCD's. Secondly what type of CD-R(W)'s it will take. Once you have got that sorted out, I would read through the "how to" guides. If you still have problems, ask again.
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 07:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 12:13 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 07:38 -
Help a newbie with BR burning... please.... :)
By mefistofel_666 in forum DVD & Blu-ray WritersReplies: 8Last Post: 3rd Dec 2009, 16:11 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43
