When I'm editing video, I'm loading Adobe Premiere and then After Effects and then 3D Studio Max, and then back to Premiere.
By this time, my computer is struggling soo hard, its almost faster to reboot my machine. I only have 384 megs of ram, but is there a way to reset or clear the current memory of these programs? Windows will store parts of the program in memory so it will load faster next time you use it.
GRRR ... When I reboot, all works fast, but after a few Premiere loads and an AfterEffects, there it struggles again.
Thanks,
HI,
Use the contorl-alt-del key to bring up the windows task manager and then click on processes, here you can end tasks that are running , once you figure out which tasks are not needed.
But frankly you should get more memory at least 512, a gig would be preferable especially running the programs you mentioned
peregrin -
Half the processes I have no idea what they are ... But I have closed these before. The computer runs slow after I have closed all of my programs ... ie premiere, aftereffects, etc.
I know I need more memory, I need a new computer for what I'm doing. But I have closed a lot of the processes and it helps, but still the harddrive struggles a lot. I've got two harddrives, but C will just struggle and when I hit C+A+D, it says my System Idle is at 98% when the harddrive is constantly running .. clicking away.
Maybe there isn't something to remove programs like that from memory once you close them
Thanks, -
Besides more CPU and more ram, You might want to move all temp files and scratch disks to HDD other than the one that holds the system swap file.
Also defrag often.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
Premiere Pro Memory Usage is Extremely high
By jbandy1 in forum EditingReplies: 1Last Post: 31st Jan 2009, 03:07 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
Adobe Premiere Elements 4 - How Much Memory?
By oldandinthe way in forum Authoring (DVD)Replies: 0Last Post: 8th Nov 2007, 14:05 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31
