Posting this here since it's PSX-related and I am not sure which forum it should go to.
Please note, that, YES I realize this is a PSX-related question and being posted on a CD/DVD media discussion board, and YES the products in question are legally obtained and owned. I do not condone piracy in any form.
Now that that is out of the way, the reason I am posting this here is because my problem has to do with the conceptual differences between PAL and NTSC video signals. Let me explain.
I moved to the US from Europe, and brought with me a bunch of PAL psx games, and a PAL console, with the controllers, memory cards, the shit. However, although I fixed the voltage issue with a step down transformer, it turns out that I cannot seem to be able to get the video signal to display properly on the American (NTSC) television set (brand new Hitachi 28", bought this spring).
I knew this would happen, so I purchased a PAL-to-NTSC converter from Chipzone...which did not help one bit. I sent it back and got a replacement...and it doesn't work for me either. The problem is that the resulting image has the right colours, but it is extremely jumpy. It's a pity since the audio works fine and the colours are there.
I asked about the refresh rate differences (50 Hz/60 Hz) but the blokes at Chipzone said that it does not matter; the converter works with a PAL psx and an NTSC tv set.
Yeah well, it doesn't. Any ideas? I am under the impression that the refresh rate of a PAL tv set is 50 Hz, and that of a US (NTSC) set is 60 Hz. Is this precisely the problem, as I have assumed, or should the converter fix this for me?
It says on the bottom of my PSX unit: ~AC 220-240V 50/60Hz 10W. As I said, I used a step down transformer to change the voltage at the US apartment to the required. Does the mention of 50/60Hz have anything to do with the refresh rate, or is that only related to the power supply or something?
I know this is a long shot, but thanks for any advice you can give. I am also sorry for such a long post and the redundancy of my questions, but this is something that is really bugging me and I want to find a way to fix this. Or at the very least understand why I cannot.
Results 1 to 1 of 1
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
recording 3D field sequential ntsc signal to PC
By shpitz in forum Capturing and VCRReplies: 14Last Post: 22nd Sep 2011, 13:30 -
capturing PAL signal as 1080i, 720p or just PAL ?
By adom in forum Capturing and VCRReplies: 3Last Post: 30th Aug 2011, 06:10 -
Convert PAL Signal to NTSC for USA HD Plasma
By hilite in forum DVB / IPTVReplies: 5Last Post: 25th Aug 2011, 07:11 -
Converting PAL RF tv antenna to NTSC RF antenna signal?
By SamGR in forum Newbie / General discussionsReplies: 17Last Post: 23rd May 2007, 15:05
