When I try to convert some AVI to burnable DVD Files using Nero Vision Express I allways get error messages. Have tried different AVI's, with xVid MPEG4 Codec or DivX 5.03. Audio has always been MP3. In all of these cases i got one of the following error messages:
1.
***BEGIN: Component Error Handler
Error Code: 14
Source: CAC3Encoder::Initialize
Description: cannot find NeAcEnc.dll
ERROR:
cause: 128 (nmc_processing_exception)
source: CAC3Encoder::Initialize
description: cannot find NeAcEnc.dll
2.***BEGIN: Component Error Handler
Error Code: 11
Source: StartStreaming
Description: Cannot seek graph to segment start
ERROR:
source: StartStreaming
description: Cannot seek graph to segment start
Can somebody help ?
and if I want 2-channel Dolby also, seperate audio and convert it with BeSweet to ac3 ?
You may not have the Vision Express-specific Mpeg2 encoder plug-in. (Different from the Nero Burning Mpeg2 encoder plug-in)
If you really want to use Vision Express for projects, the last version I tried would always try to re-encode the video file whether it was already encoded properly or not. -
I am using newest version 2.0.0.22, where the plugin is already included. I have also checked about this missing file NeAcEnc.dll, it is part of the installation.
Problems writing with nero vision express 3
By tatester in forum Authoring (DVD)Replies: 3Last Post: 11th Feb 2009, 17:38 -
Recording audio with Nero Vision 4 Express
By SEE_Studios in forum AudioReplies: 3Last Post: 21st Jan 2008, 16:28 -
Sudden problem with Nero Vision Express 3.1.0.0
By smackyourfupa in forum Authoring (DVD)Replies: 8Last Post: 3rd Nov 2007, 17:56 -
better tha nero vision express
By cesarin in forum Authoring (DVD)Replies: 1Last Post: 24th Jun 2007, 14:34 -
join and burn using winavi and nero vision express?
By leogeo in forum Authoring (DVD)Replies: 9Last Post: 11th May 2007, 07:56
