I was trying to convert my svcd movies onto dvdr
I copied all the mpg files from the disks, merged these, then demuxed, Then ran Besweet on the audio file, then ran the files through ifoedit
And go them into vob files, i tested the files with power dvd and the files played the movie perfectly,
I burned it onto dvd video using Nero and when i tried the DVD in Home DVD Player it came up detecting a CDROM and asking for a playable disk.
Whats gone wrong ?????
I thought i was well on the way to gettign my vcd/svcds movies onto dvdr but it didnt work
All advice is gratefully recieved
Can you email replies to lee.egglestone@durham.gov.uk
Lee
well...i'm thinking of 3 possibilities...
1) first make sure your dvd player supports DVD-R and DVD+R...check here: https://www.videohelp.com/dvdplayers
2) you might be burning the DVDs as UDF 1.05 in nero.... not all dvd players support this... UDF 1.02 is much more compatible with dvd players...here's a guide: https://www.videohelp.com/forum/viewtopic.php?t=127624
3) essentially, you have made a SVCD-DVD. however, keep in mind SVCD specs are NOT compliant DVD specs...meaning that you just made a non-standard, compliant xDVD, which has lower dvd player compatibliity than standard DVD.
so, you might need to convert/re-encode your SVCD MPEG-2 to DVD compliant MPEG-2...so, you can make a fully compliant, standard DVD.
guide here: https://www.videohelp.com/mpeg2tovcd.htm
and lots of SVCD to DVD guides here: https://www.videohelp.com/guides.php?howtoselect=3;29
is 1080p shown in Height in mediainfo?
By justravis in forum Newbie / General discussionsReplies: 8Last Post: 24th Feb 2011, 17:48 -
Have the TY JVC discs shown up at retail yet? Will they?
By Bix in forum MediaReplies: 40Last Post: 29th Sep 2010, 10:47 -
How to force subtitles to be shown in certain parts of the DVD?
By dexter30 in forum SubtitleReplies: 1Last Post: 24th Jul 2009, 19:58 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 16:48 -
Cyrillic subtitles not shown corectly on DVD player
By uher in forum SubtitleReplies: 1Last Post: 10th Dec 2007, 14:05
