I was trying to convert my svcd movies onto dvdr
I copied all the mpg files from the disks, merged these, then demuxed, Then ran Besweet on the audio file, then ran the files through ifoedit
And go them into vob files, i tested the files with power dvd and the files played the movie perfectly,
I burned it onto dvd video using Nero and when i tried the DVD in Home DVD Player it came up detecting a CDROM and asking for a playable disk.
Whats gone wrong ?????
I thought i was well on the way to gettign my vcd/svcds movies onto dvdr but it didnt work
All advice is gratefully recieved
Can you email replies to lee.egglestone@durham.gov.uk
Lee
First of all
WHAT DVD DRIVE is burning these?
What firmware does it use?
What Media do you use
What Version of Nero?
What Method in NERO (DVD VIDEO , DVD ISO or do you burn an image (.nrg or other)?
Also if you make a mistake in your subject head, don't double post, EDIT the orig! -
The DVD rewriter drive is a Pioneer 1x speed, i think its the A4 version or A04
I dont know the firm ware, i put the dvd writer in and windows xp installed it for me. Ive managed to copy a dvd to a dvd so it seems to work ok.
The media i used was a 4.7g general use DVDR
I have Nero Version 55914
The method was DVD Video
Hope this helps
Lee -
You did it all correct
The only thing I reccomend is you try again with a BLANK made in JAPAN not TAIWAN (hard to find them I know)
or try STOMP RECORD NOW MAX (came with my A04 at work bundled)
Multiple displays
By alintatoc in forum ComputerReplies: 2Last Post: 18th Dec 2010, 16:53 -
Dual DVI Displays
By Chris J Shaw in forum ComputerReplies: 9Last Post: 6th Mar 2010, 00:11 -
Dual displays: how to display same on both?
By Quimbly in forum ComputerReplies: 10Last Post: 22nd May 2008, 20:48 -
Split TV for 2 Displays... (help!)
By zephirus79 in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2007, 21:46
