had you ever have a problem burnning media with nec 1300 drive on generic media such as lead data, princo or ritek at 4x? My brother has a nec drive and he found out that nec 1300 drive would not accept any media unless is branded known media such as tdk or so on media. anyway, if you have some experience on this drive, please let me know your comment on it of how to do so. My brother is thinking about return his drive back to vendor.
You should upgrade the 1300`s Firmware to expand the mediasupport
of your writer...
look here...
http://herrie.rpc1.org/there is only one thing alive and
well here... - evil! -
this is a know problem with the nec drive. you need to use a hacked firmware if you want to use those media.
Could anyone give help on how to install firmware cos im struggling badly.
Cheers -
Just follow my Link!!!
There you'll find the hacked
Firmware and advice how to use/flash ...there is only one thing alive and
I've upgraded my nec1300a oem to herrie's 1.6 and it still will not verify a burnt ritek 4x DVD-R. I still haven't bought any different media because i paid £250 for 200, i literally have to get it to work with them. has anyone got any ideas, they seem to run alright when played back in PS2s and Standalones but whenever I try and actually copy the data back onto the PC I get CRC errors straight away
'Imagination is more important than knowledge' - Einstein -
You may want to check in windows device manager and make sure the NEC drive has DMA enabled. If not then maybe try un-installing the drive in device manager then re-boot allowing windows to re-install the drive and hopefully enable DMA.Originally Posted by RinseOut
If you want to copy from a DVDR I would suggest using SmartRipper to do that, not windows exployer. -
I installed the hacked firmware and it has worked perfectly. highly recommended. Actually the drive was almost useless before I flashed the firmware with the media hacked version.
Problem DVD/can I make a generic .IFO file?
By ambrosechapel in forum MacReplies: 13Last Post: 3rd Nov 2009, 22:49 -
HP Pocket Media Drive. Anyone know how to replace the drive?
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 3rd Jul 2009, 16:08 -
burnning dvd
By brenjim in forum Video ConversionReplies: 14Last Post: 2nd Mar 2009, 13:44 -
Guide to fix Illegal Disc Error for NEC drive (possibly others)
By lucaschrist in forum DVD & Blu-ray WritersReplies: 10Last Post: 5th Apr 2008, 02:11 -
DVDFab Platinum generic.xvid.mp3 audio problem
By JoeWillis in forum DVD RippingReplies: 0Last Post: 29th Aug 2007, 19:59
