i just encoded an avi file to mpeg using tmpgnc, the picture quality is really poor now, theres a lot of breaks in the picture now. i ran it through Mpeg-corrector and it still looks the same, now my question is did i encode it incorrectly using tmpgnc?
i encoded aspect ratio:1:1(vga)/60 fps/1150 kbs/high quality/MPEG-1 Someone let me know why there are boxes appearing in the file when i play it after encoding
Was the original AVI poor quality? =|
Why are you encoding @ 60fps?
<font size=-1>[ This Message was edited by: Jeomite on 2001-09-30 19:16:37 ]</font> -
no the origibal is fine, am i not supposed to encode at 60 fps? what shoul dit be at?
Also what should the Stream Type be? (Mpeg-1?) & VIDEO SOURCE TYPE (Non-Interlace??)
There is no reason to encode @ 60fps. I even bet your source AVI wasn't even captured @ 60fps (so where is all those extra frames coming from - your output MPEG will look so 'laggy' or 'freezing', that is why your picture is 'breaking' or 'freezing'). Double-check if you captued your AVI @ 29.97fps (25fps for PAL). Then load the VCD Template (that came with TMPGEnc). Change the to High-Quality setting as desired and give it a go. Should turn it fine...
How to repair a damaged MPEG-file ?
By d98rolb in forum Video ConversionReplies: 2Last Post: 5th Oct 2009, 02:03 -
repair file
By volam in forum EditingReplies: 1Last Post: 30th Aug 2009, 10:14 -
best program to repair time in a mpeg
By ziptip in forum Newbie / General discussionsReplies: 3Last Post: 30th Dec 2008, 05:02 -
repair a TV without electrocution
By AlanHK in forum Newbie / General discussionsReplies: 2Last Post: 9th Aug 2008, 10:44 -
How to repair broken frames in MPEG/DVD videos
By misterbean in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2008, 23:02
