Hi, I have a pentium 3 1GHZ proccesor. Ive been wanting to upgrade my computer for sometime now so my video encoding would go finish faster. At the moment the fastest speed for Pentium 4 is 3.2 GHZ. I was wondering if anyone here knew when the next generations of Pentiums will be coming out and if they would be alot faster then the current generation or about the same. Also, i was wondering if processor cache size affects video encoding times. Thanks in advance
unless you have lots of $$$ to spare, i would suggest you NOT to buy the latest CPU...because chip makers charge an exponentially higher rate on the latest processors than even 1 generation earlier...
for example... a jump from 2.8 Ghz to 3.0 Ghz may only be $50...but if you were to jump from 3.0 Ghz to the latest (assume for this example :P) 3.2 Ghz, it may cost you like $200.
so, for the same .2 Ghz jump...jumping to the latest CPU is gonna cost you lots of $$$...
yes, cache is extremeley important....... a lot of the lower end models (i.e. celeron and duron) have less cache -
3 GHz to 3.2 GHz will make a marginal difference only in my opinion. Certainly not worth the money.
*** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
Intel i5 2430M processor or AMD A8-3500M quad-core processor?
By jbitakis in forum ComputerReplies: 5Last Post: 11th Nov 2011, 20:31 -
new processor
By alintatoc in forum ComputerReplies: 6Last Post: 21st Sep 2009, 03:16 -
A question about Subtitle Processor
By tofuguy in forum SubtitleReplies: 2Last Post: 6th Oct 2008, 22:33 -
Processor
By Tom in HD in forum MacReplies: 1Last Post: 1st Dec 2007, 22:02 -
Question re. DV Processor and IRE black
By nlec in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 9th Jun 2007, 03:31
