  1. I have recently formated my hard drive so i had to reinstall all of more tools, afterwards i tried to back up a dvd. i started with smart ripper then used dvd2avi then tried to move on to tmpgenc but when i tried to browse trough to locate the file it said that the file cannot open or is unsuported. I tried it with more than one dvd and i recieved the same message.
    I have done this many times before but now it is not working.
    Can anyone help me out.
    I have also followed sefy's dvd backup guid to douple check
  2. Your problem is with dvd2avi try uninstalling it completly and having another go, If your using a shorcut, make sure it is pointing to the folder with all the files in it. Do NOT remove any of the files, keep them together.
    Good Luck
  3. As a little addon, make sure you Unzip your DVD2AVI into where you have TMPGEnc installed!
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  4. First off thanks for the help guys it got me to the next pont, but just to get stuck again. After going through everything with Tmpgenc on the fith step when it is suppose to start encoding it gives me an errormessage saying "can't load P3Package.dll"
  5. I Strongly suggest you re-download TMPGEnc and make sure you install it correctly, cause that DLL should come with it
    Best Regards,
    Sefy Levy,
