I use the "decompress"(that comes with "avi2vcd") to uncompress .ogm files so that TMPGEnc can load it and convert it to mpeg. I converted many ogm files before but then I reformated my PC and now its not working the same, when I try convert all I get is audio & no picture(its just black). I installed all the codecs I could think of but still no luck. Do you guys know the problem?
The problem your describing still sounds like a codec problem. Ensure you have the latest codecs. You should also check the OGG/OGM websites for troubleshooting tips.
Impossible to see the future is. The Dark Side clouds everything...
.ogm file
By d_animality in forum Authoring (DVD)Replies: 2Last Post: 29th Aug 2011, 08:19 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
.OGM help
By Moparbear in forum Video ConversionReplies: 2Last Post: 3rd Mar 2008, 19:08 -
OGM remuxer?
By Colmino in forum Video ConversionReplies: 1Last Post: 25th Nov 2007, 13:27 -
Question regarding .ogm
By Justin Wade in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 12:39
