  1. Hey,
    Quick question here:
    When i play an svcd i made in my player sometimes the sharpness around the peoples faces goes fuzzy when there is increased movement.
    (i capped from vhs to avi with huffy, used cce to do 4 pass vbr then encoded to mpeg2)
    Would increasing or decreasing the avg/max/min bitrates fix this?
    TIA.
  2. i am trying to fix simular problem. Not with DVD source though, those are perfect. I am having simular problem with DV AVI files, soccer game with lots of motion. Tried xSVCD but I got worse quality than SVCD?
    If your source is DVD try dvdtosvcd great results! If DV then we need some help here!!!
    Swing a hammer at it, if it doesn't fix it I gaurantee you will feel better.
  3. My source is analog captured to avi using huffy codec...
    I think my problem is a bitrate problem.
    May 2001
    God's Country
    I beleive that Mainconcept encoder has a switch called "Allow Motion Based Compensation" to supposedly help those areas with quick motion, although I have never tried it on DV soccer footage or anything.
    Cant hurt to try it I guess.
