Has anyone figured this one out?
When the audio is not 48k, you can transcode it -- and you can either choose a specific bitrate to use, or you can choose "optimal". But this is not explained in the help or anywhere else.
I wanted to believe that "optimal" meant "the same bitrate as the source", but this doesn't seem to be the case.
I just used Audio Transcode with the "optimal" setting, and the transcoded audio was smaller than the original! This is really lousy, since I picked the source files so they would exactly fill a DVD!
So how does DVD-Lab determine "optimal" audio bitrate?
Results 1 to 1 of 1
Optimal tracking for video != optimal tracking for audio
By miamicanes in forum RestorationReplies: 4Last Post: 16th Oct 2014, 12:52 -
VOB to .H264 FFmpeg Transcode Bitrate and Slow Seeking
By Gloriosis in forum Video ConversionReplies: 3Last Post: 9th Sep 2009, 15:34 -
How to set optimal bitrate for MPEG
By peterbuilt in forum Newbie / General discussionsReplies: 2Last Post: 17th Mar 2008, 12:13 -
Optimal Video Bitrate and target DVD size
By src2206 in forum Authoring (DVD)Replies: 22Last Post: 24th Oct 2007, 07:54 -
ConvertXtoDVD does it find optimal mpeg bitrate for you?
By supaguy in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2007, 16:13
