Hi, I have a mpeg file that is 1 hour long. I would like to copy a 5 minute segment in the middle of the file. How do I do this and what is the best program to use?
Thanks in advance
I use MpegVCR 3.14 to capture clips from movies. Just mark in mark out and save works very well. I have been using MpegVCR for the last year and have been very impressed with it.
Good Luck,RickASUS p4c800
1 gig ddr 400mhz ram,2.6 P4 800mhz fsb
15gig,40gig ata100's
pvr250 capture card
Geforce4 128mbddr mx440 video card
Datavision TBC3000 time base corrector
creative live sound
Sony U10A dvd-rw,sony crx-160e cd-rw
windows XP
persistance -
Use any decent editing program listed in the tools section of this website. Just trim the parts yoiu don't want and make a new video file of the 5min segment. I use Ulead Video Studio7
MpegVCR is good here's a guide:https://www.videohelp.com/mpegvcredit.htm
..or you could use DVDx -
@eteo,
first and foremost...you need to figure out what type of .mpg file you have there...
is it a VCD MPEG-1 or SVCD MPEG-2...
look here for guides: https://www.videohelp.com/edit
personally, i would follow this: https://www.videohelp.com/tmpgencedit.htm
Fastest way to create segment from video file?
By therock003 in forum EditingReplies: 8Last Post: 23rd Apr 2013, 17:13 -
Help:VDUB:CANNOT APPEND SEGMENT segment has a different number of streams
By lil_Dee in forum EditingReplies: 9Last Post: 23rd Jun 2009, 08:16 -
Only First Segment of VOB File Converts/Encodes
By stevenjgarner in forum ffmpegX general discussionReplies: 2Last Post: 11th Mar 2009, 22:52 -
How to copy a video segment from my DVD-Camcorder
By dark_cyber in forum EditingReplies: 6Last Post: 15th Oct 2008, 02:20 -
downloading a segment of a wmv file?
By kruuth in forum Video Streaming DownloadingReplies: 0Last Post: 15th Apr 2008, 21:28
