I have encoded an avi to mpg2 using CCE 2.62
Spec
3 pass VBR
Average 2608
min 1000
Max 9000
When i play the burnt DVD on pc it plays beautifully but on stand alone it shows up all wavey an lines etc especially on scene transtions and movement.
My question is does this problem occur from the bitrate going from low to high??? hence it play's fine on my pc due to buffering and DVD rom being able to read much more data then a standalone at one pooint in time
The souce was a vhs should i even go that high in max bitrate....the movie is 3 hrs long hence the lower bitrate in order to fit on DVD-r....
How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
If you like Tekno download one of my tracks
www.users.bigpond.net.au/thefox149 -
Post a sample frame. It's probably field order.
Impossible to see the future is. The Dark Side clouds everything... -
What makes you think that you have a bitrate spike? Did you view your bitrates in Bitrate Viewer?
A DVD is read at a constant 26.13Mbps data rate, so there shouldn't be any problems with high bit rates. You probably have a problem with the structure of your creation.
Also, 2.6Mbps is a little slow even for a three hour video. I would imagine that 3Mbps would be more optimal, which would leave about 500+ Meg for the audio and menus.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
when i capture a frame the error isn't there....
This is weird. I have already changed the field order but still getting it the problem. I was having the same problems when ReelDVD was installed i removed it the problem went away i could play them on my pc fine ...now it's back so i have unsitalled dvdlab (though it might have been related now its here to stay)....How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
this error only occurs when i resize using Avisynth 2.5. Are then any mulitmedia settings that could effect it .
the script is basic
AVISource("C:\CAPTURE.AVI")
Trim(10000,12000).Fadeout(120)
Crop(8,2,338,558)
LanczosResize(352,576)
I just don't get it
This also occurs when i have used avisynth 2.07How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
Maybe your captureprogram is deinterlacing on the fly? when you load the file into TMPGEnc it will make all necessary changes in Source Type on its own. It's usually right......
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Spike HD users - is Star Wars ever in 5.1????
By yoda313 in forum Off topicReplies: 9Last Post: 18th Aug 2009, 19:56 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Canon HF10, *HUGE* price spike in same day?
By RogerTango in forum Off topicReplies: 8Last Post: 17th Feb 2009, 23:35 -
Removing a Spike from an Audio Event?
By solarblast in forum AudioReplies: 5Last Post: 10th Dec 2008, 21:03
