I have just bought a new Sony DVD + and - Burner. Not sure what software comes with it yet but am looking to purchase good software. I currently own about 50 dvd's and want to make copies of them as they are getting scratched by use but understand that they have protection. Cany any one recommend good software to use? Thanks Also is dvd + or dvd - blank dvd's the way to go? As this burner supports both, im not sure of the differences. Information would be much appreciated for a first time user.
Here's a good article that should tell you everything you want to know:http://www.cdfreaks.com/article/117
For media, check the model and look it up in the "DVD Players" section on the left toolbar. It should tell you which media is more compatible.
I urge all newbies to look at the guides FIRST and then ask corresponding questions.
If you have any further questions, feel free to ask...THIS has been an RVL123 production... -
Originally Posted by josh.c
cue terminator theme :P
i'll let other ppl handle that one
but, most important format to go with is which ever your standalone dvd player supports...check here: https://www.videohelp.com/dvdplayers
good overview: https://www.videohelp.com/forum/userguides/141024
good guide on FREE DVDshrink: http://www.doom9.org/index.html?/mpg/dvdshrink2-main.htm
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 04:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 09:07 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 22:45
