I am interested in making a DVD using a few selected scenes or chapters from other DVDs. (Primarily, I want to make a private home theater demo discs using clips of commercial DVDs I own.)
Can anyone tell me what is the best way to do this? How can I rip certain chapters from a DVD to the DVDR without having to rip the whole movie?
Any help would be greatly appreciated.
Thanks!
Diesel
Rip the movies to your computer and make mpg files out of them with TMPGEnc (using DVD2AVI to make a d2v file). Then use TMPGEnc to cut and join the video as you wish.
I'll try that method. Thanks for the feedback.
Is there a loss of quality going that route, by the way?
Diesel -
I think that this discussion will help answer your question, without losing quality.
btw, other authoring software also imports VOBs (TMPGEnc DVD, I think). -
There is a way to do this while preserving the original quality
Here is how:
a) use SmartRipper to rip one VOB per chapter, select chapters to want to rip
b) import these VOB files in IFOEdit to author a DVD (use the Guide from this site about IFOEdit)ktnwin - PATIENCE -
Thanks again for all the help.
However, when I convert a VOB file to MPEG, I lose the audio. Should I have gone through a demuxing or muxing process?
Diesel -
I tried a couple of programs but IMO DVD author is by far the easiest to use for this sort of work. it imports vob files, just limited in menus unfortunately but I had some luck with importing other menu templates from other programs, ie Pinnacle or MF2 even a motion menu with sound.
What kinds of files are "Best" for making a dvd out of?
By RBCC in forum Authoring (DVD)Replies: 13Last Post: 5th Mar 2012, 18:35 -
best software to make "fair use" backups of DVDs to DVD +/-R?
By gastrof in forum DVD RippingReplies: 4Last Post: 14th Jun 2011, 15:27 -
Making a Toast "DVD Video" Disc
By albloom in forum MacReplies: 5Last Post: 22nd Apr 2008, 12:45 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 09:08 -
"resume play" feature for dvds burned by dvd recorders (pioneer d
By barninga in forum DVD & Blu-ray RecordersReplies: 9Last Post: 19th Nov 2007, 03:11
