Anytime I try to run this program through the terminal, I get the following error:
Any idea why, and how I can fix this? I really want to get the New Ren And Stimpy online, but MEencoder seems to leave a one second delay with the audio, so I wanted to try this program instead.Originally Posted by Terminal
Results 1 to 10 of 10
IUGGuest
IUGGuest
Crap, can't edit, so...
IUGGuest
I exported the orginal movie from iMovie as full motion DV, but the file extention is .mov (usually DV files are .dv, so I'm a little unsure on that). I tried to encode it as MPEG4 [.AVI] (ffmpeg).
IUGGuest
Thanks, it seems just changing the file extension did it. I'll just post back in a while and see how the coversion went.
IUGGuest
Yeah, I did convert it, this time with ffmpeg, and I got an even longer delay between my audio and video that I did with Mencoder. The video seems to be going at about 3/4 the speed of the video.
IUGGuest
Thanks, you guys all kick ass, and can leech the new Ren And Stimpy off of me anytime.
Hi, I am also getting the same ppmpipe problem. I have tried encoding everything using the ffmpeg thing, and it won't work. When i try menencoder it seems to work, but I'd like to try both to see quality etc. I've tried divx, mpg1, mpg2 and still same ppmpipe problem. I am running osx 10.2.6, 1ghz imac, ffmpeg 7.c and using btv to capture dv (through cannopus acdc 100) into quicktime file with .mov extension. I just find it odd that I cannot use ffmpeg encoder with any file types I use. I also cannot get the preview option to work at all. Just curious how to fix this. Thank you!
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
MeGui: error in encoding: "x264.exe:unrecognized option --progress"
By Julllie in forum Video ConversionReplies: 4Last Post: 30th Apr 2011, 06:21 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
