I have a VHS tape with still images from an old reel of film that I plan to put onto a DVD. Since there is no motion on this DVD, what bitrate would be a good choice to encode this w/ TMPGENC? Also, should I bother with any kind of filters during capturing if the original is in really bad condition anyway? Thanks for the help guys.
Good question, although I am not sure if I have a perfect answer for you.
The truth is, it is mostly about the length. If your entire clip is only half an hour long, then just do it at a good high bitrate, you won't be losing out in any way, and you are ensuring quality.
The problem with capturing the images from an old VHS tape is that there will most likely be movement from frame to fram because of jittering, dust, etc etc. This will increase the number of changes frame to frame, so the bitrate would still have to be higher than it would if you were authoring the video directly from the still pictures.
Anyway, hope that helps a little.
Software for editing a converted “VHS to DVD” then burning a new DVD?
By TinCanTheClown in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2011, 19:58 -
Creating DVD with stills, need advice on upping the quality.
By RebeccaDesigns in forum MacReplies: 6Last Post: 4th Aug 2011, 10:29 -
transferring old vhs tapes to computer for editing and burning to dvd
By michael109 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Sep 2008, 11:00 -
pixel aspect ratio in stills for dvd
By SexMoron in forum Authoring (DVD)Replies: 7Last Post: 4th Jan 2008, 08:11 -
How to capture stills from a Video DVD slide show?
By riti in forum Newbie / General discussionsReplies: 3Last Post: 12th Jun 2007, 01:26
