Using TMPGenc:
When you run the multiplex tool, from the MPEG Tools section, and load the m2v and mp2 files it will set your Type to: MPEG-2 Program (VBR)
You need to change it to MPEG-2 Super VideoCD (VBR)
Then you dont get the autopadding problems.
Took me way to long to figure that one out :P
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Ejoc, you are jumping to the conclusion that we all know how to use all of those programs (and command line?). You're answer only made my confusion worse. And why use huffy in there anyway. What is it's purpose?
You could just have asked!Took me way to long to figure that one out
/Mats
What is this called and how do I fix it?
By jarlaxle in forum Newbie / General discussionsReplies: 5Last Post: 28th Feb 2012, 03:08 -
Fix my Speakers
By carreaza in forum AudioReplies: 4Last Post: 14th Oct 2011, 20:57 -
Is it possible to fix that ???
By cd090580 in forum Newbie / General discussionsReplies: 8Last Post: 8th Sep 2009, 15:46 -
how to fix h264?
By hanugro in forum Newbie / General discussionsReplies: 9Last Post: 13th Mar 2009, 22:02 -
AVI, Nothing will fix it! I have done all I know!
By bl00dy fl00r in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jun 2007, 18:02
