I have been using TMPEGenc 12c to cut (S)VCD-mpegs. I recently copied 6 VHS tapes to DV & then encoded them to VCD copmliant mpegs. I then split the files up into several chapters using the mpeg tools section of TMPGenc 12c. I had no problems with the first 5 tapes. But now whenever I try to split the last mpeg file into chapters, TMPGenc 12c freezes. I tried hitting play & then pause and setting an output file prior to editing but nothing works. As soon as I try to mive the slider, TMPGenc freezes. If I try to enter start/stop times manually, TMPGenc freezes. The only way I can edit out clips is if I hit play and hit the start & stop buttons when the movie reaches that point. However, this isn't a real solution b/c the file is ~90min and every time I reopen the editing box the file is back to the start position.
If this is just a problem with v12c, how come it worked for the other 5 files?
