I have been trying to edit video (avi, mpg1 and) with Premiere and no matter what settings I use, I get clicks in the audio at regular intervals throughout the clip.
Been trying to convert to vcd/svcd mpg format.
Anybody have any hints how to get rid of the clicks?
Try toggling your audio interleave, you'll find it in the export movie settings (click next). It should be set to .5 or 1. I read somewhere that if it's set too high it could cause clicks or gaps in the audio.
ChachiFace
Importing video/audio into Adobe Premiere Pro CS3
By JCW2001 in forum EditingReplies: 26Last Post: 15th Jan 2011, 21:39 -
no audio in adobe premiere cs3
By vin4evr in forum Authoring (DVD)Replies: 1Last Post: 22nd Dec 2007, 13:28 -
[Solved]Adobe Premiere Error : Unsupported Audio Rate
By anindyanuri in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2007, 11:33 -
Problem with audio in Adobe Premiere Elements
By marioman1234 in forum EditingReplies: 2Last Post: 28th May 2007, 13:45 -
Matching different video clips/Zooming in on audio in Adobe Premiere
By PharmBoy in forum EditingReplies: 3Last Post: 20th May 2007, 16:42
