I'm making a backup of "Queen+ Freddy Mercury Tribute". The DVD has PCM audio and DTS, no Dolby Digital. I used IC7 and had to eliminate the PCM track because it was huge, it was calculating 46% of video compression. Once I removed PCM it gave about 67%. One more thing worth noting is that the bitrate of that concert is high, almost superbit.
Once IC7 finished I burned and tested it on my standalone (Pioneer), and the backup didn't run correctly. The menu runs perfectly, but the concert is extremely messed up, like when you've made a XVCD with a very high bitrate that your DVD can't handle or like you've got heavy rain on your satellite dish.
Then I burned again the concert on a better DVD-R that always gave good results on my Pioneer standalone and got exactly the same results. I burned another thing on a good DVD-R to test if my burner is working fine and that copy ran ok, so the burner, standalone and media are ok.
I don't know if the removal of the PCM track affected the playback or if the resulting bitrate is to high for a DVD-R to handle. Which is the limit bitrate a DVD-R can handle?
George
IC7 won't, to the best of my knowledge, make a DVD with a bitrate so high that it can't run properly.
I mean, it only COMPRESSES bitrate, it doesn't EXPAND it, and the original runs, yeah?
I'd guess that something just got munged up in the transcoding.
- Gurm
Weird (to me) subtitle problem
By alvabass in forum SubtitleReplies: 3Last Post: 31st Dec 2011, 13:50 -
DVDStyler weird problem
By xeroblast in forum Authoring (DVD)Replies: 0Last Post: 8th Sep 2011, 01:37 -
weird sd card problem
By fromunda kid in forum Newbie / General discussionsReplies: 8Last Post: 16th Feb 2010, 12:52 -
any1 figure out THE QuEeN
By steamedPS in forum DVD RippingReplies: 8Last Post: 12th May 2007, 19:14 -
Stymied by The Queen
By patsy murphy in forum DVD RippingReplies: 20Last Post: 10th May 2007, 06:47
