I have several 8 mm tapes I'm trying toconvert to DVD's. They won't play due to moisture. Thy've been that way for over a month. Does anyone know how to dry them out to make hem playable.
Sherm
Sherm
Try to collect some of these silicate bags (or buy some at you chemists).
Put tapes and silicate together in a sealed box.The silicate will absorb any moisture.You can re-use it by roasting it at mild temperatues in the oven. -
Is it just several tapes or all tapes. My 8 mm Sony won't read any tapes due to a moisture sensor error. Just curious if others have had that problem.
I solved the problem, but there are only a few pople that will benefit. I wear hearing aids, so I put the tapes in the Hearing Aid drier. They work now.
It was 3 or 4 tapes out of 30-40 tapes.
Thanks for the help.
ShermSherm
Need Help With An Avast Warning
By hech54 in forum ComputerReplies: 9Last Post: 21st Feb 2010, 03:18 -
funny warning sign
By freebird73717 in forum Off topicReplies: 0Last Post: 20th Aug 2009, 19:26 -
Standard TV warning
By djmobius in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 24th Jul 2008, 07:10 -
Warning: implode()
By handyguy in forum FeedbackReplies: 1Last Post: 24th Aug 2007, 13:02
