    Mar 2001
    radcliff
    i have downloaded an application and it came in rar format. i extracted the files to the folder and extracted the bin file to the same folder. but i have 1 problem trying to burn or convert to a format in order to use it. can someone help
    Sep 2001
    Japan
    If there is an additional .cue file, mount this one using DaemonTools.This will act as normal CDROM, which can be copied,installed or whatever.
