  1. hey,
    I'd like to know how I can transfer a video file like: .mpeg, .avi, VCD, SVCD;.... to a VHS.
    I got a ASUS AGP-V8460Ultra/TD, GeForce4 Ti4600, 128MB DDR, DVI, TV-out, AGP graphical card and the required cable to connect my VCR with the computer.
    1.) Is it possible to do that with my card (http://www.asus.com.tw/vga/agpv8460/specification.htm) ???
    2.) How would I do that ? Or which program would I use ?
    I am sorry if that had been discussed/answered before but the forum search is temporary unavailable and I have to ask here (again).
    thx for any help in advance
    nothin much is left to say...
  2. yes. First you need to tell your card to output on the svideo (or component, depending on what your using). Your manual should tell you how to do that. after that, just play the movie at full screen, and press record on your vcr.
