So here we go - the process to get here was rather extreme but I finally got a dual audio " vob " file
how did I get there ??? alright
I had one divx file( picture and english sound ) and a mp3 audio file ( german )
I run the divx trough TMPGenc to create a m2v and the mp2 file .
I converted with besweet the english and german files into AC3 files
Ifoedit created the next step and vobmerge made one file out of them - finally I got dvdlab for the compilation .
Now I did try to create a dvd with TMPG DVD Author but when I select " bilingual " it gives me some errors about that you cant reencode the ac3's
when I start the vob itself than power-dvd starts and plays fine - I can switch the two languages
What now ????????
Results 1 to 10 of 10
What was this next step, IFOEdit created? After authoring with IFOEdit You should have been ready to burn.
aha - hmh I got to check on that - but there was some guide in here that explained taht there would be only this way
Nope, IfoEdit is just the way:add the video and both ac3 tracks, edit the language properties (like assigning 0x80 to the English and 0x82 to the German track) and let ifoedit do the rest.
You are ready to burn your DVD then. -
@ Dragonsf
seems to be that you are about right up to a certain point - both languages are present and switchable , POWER DVD playes it and my PS2 as well but my Panasonic DVD will not even see the DVD - and there seems to be here and there some slight freeze-ups
Dual Layer burn issue with TMPGEnc Authoring Works 4
By am_dew in forum Authoring (DVD)Replies: 3Last Post: 7th Feb 2012, 09:36 -
Need help authoring DVD from VCD mpeg files with dual audio..
By siratfus in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2010, 05:31 -
dual layer authoring
By miniboss91 in forum Authoring (DVD)Replies: 2Last Post: 20th May 2010, 03:37 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
Program switches audio track priority of dual-audio assets
By PBear in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 16th Nov 2007, 20:36
