Thanx for the info ipa and AlmostAborted...
Results 31 to 32 of 32
Arcorob,Originally Posted by arcorob
I've used both the Canopus and the DAC. BOTH are very good! source is everything. TBC units will aid tremendously in keeping the units from locking up. The Canopus ADVC 100's strong and weak point is the "Audio Lock" feature. If you have a TBC running both are as spectroelectro has said bullit proof. My personal experience is the Canopus is prone to be less tollerent to poor source most likely attributed to a side effect of the "Audio Lock" feature.
I can make the Canopus lock with FF and Reverse. On the flip side the DAC 100 will continue to import through FF, Reverse and minor source imperfections. The major differences in the units are...
The DAC 100
1) The DAC 100 is $100.00 LESS $188.00 delivered.
2) The DAC has no Macrovision support (No MV worries)
2a) No audio lock, no mis synch stumble from bad source. (But if it's pretty bad you'll lock this as well as the Canopus.)
3) 30 day return policy, don't like it return it, Warranty 1 yr parts and labor, 3yrs parts
4) Got a problem, pick up the phone get someone on the phone when you call.
5) Does not matter what kind of FW card you use works with all.
1) Has Macrovision support. BUT it can be disable by using the "hack" by holding down the button on the unit.
2) Audio lock, This is either a good thing or a bad thing depending on the source.
3) Good warranty, Experience from many including me, a bit harder to get support easily. Phone tag, etc...
4) Issues with TI based FW cards.
I use my DV converter to keep use off of my camera, but when the souce is a problem child then I'll record to it and import. Here is a thread I started a while back about comparine the two. A lot of people had some really good info on the subject.. Here's the link!
https://www.videohelp.com/forum/viewtopic.php?t=157074&highlight=Windows to get a job, Unix to rape clients for $$$, MS BoB for MCM (Mac Cult Members) Mac's for my Toddler to play games on and Linux for the rest of us!
The difference between genius and stupidity is genius has limits. A. Einstien
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
What's a used videodata dac-100 worth?
By zoobie in forum ComputerReplies: 0Last Post: 26th Oct 2008, 03:52 -
Have DAC-100, need HD
By The Waco Kid in forum Capturing and VCRReplies: 0Last Post: 21st Mar 2008, 19:41 -
DAC-100 dip switches
By Steinninn in forum Capturing and VCRReplies: 0Last Post: 6th Dec 2007, 21:31 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 09:15
