Hey! I was wonderign since there are a number of Codec for AVI, are there any codecs that support Transparent Colors, like GIFs and stuff?
If you have an uncompressed AVI you basically have 25 BMP pictures per ssecod in PAL right? and in MJpeg.. is'nt that just 25 JPEG pictures persecond...
Should'nt in then be possible to just just PNG pictures and save that Channel info thingy there? then you woudl be able to do transparent AVIs right? Is it hard to do a codec like?
Results 1 to 1 of 1
Thanx/
Lars
How can I make alpha transparent AVI file
By MI6 in forum EditingReplies: 4Last Post: 2nd Nov 2011, 15:02 -
converting avi to avi transparent
By perfection in forum Video ConversionReplies: 1Last Post: 8th Jul 2011, 13:26 -
A program that create transparent animation
By Cazz in forum EditingReplies: 11Last Post: 5th Jun 2011, 13:08 -
subs look transparent (sub/idx)
By X_Splinter in forum SubtitleReplies: 2Last Post: 22nd Dec 2010, 10:26 -
Transparent logos, aegisub and AviSynth
By shorto in forum EditingReplies: 17Last Post: 20th Feb 2010, 19:35
