Can SVCD2DVDMPG+ handle SKVCD?
dunno, never tried. Can you send me a link to a sample mpeg & I'll give it a go?
notskiGuest
sorry....cant find a sample.
[Edit by ChrissyBoy]
120 mins fit on 1 CD, same quality as SVCD.
sorry again. thx. -
Guest
You better edit your message before you get a warning cause warez information isn't allowed in posts. So no file names, no servers or newsgroups, etc
You can make a sample yourself. just use tmpgenc. Under file there is an option mpeg tools you can cut/join mpeg files in there. Just cut a bit out of the mpeg and save it..
Greatings,
Yf
