alot of my movies come out looking great but i keep getting annoying pauses in playback (a 5sec pause or longer) every 5 - 10 mins)
they r straight vob files converted to svcds
any ideas?
I use telecide pal compression
Results 1 to 30 of 57
Rock On
Maybe using the Telesync Pal option is the problem, if your encoding straight from Vobs there is no need to use any of the Interlace/Deinterlace in DVD2SVCD.
Also if your encoding an NTSC 2 PAL and you use DVD2SVCD NTSC2PAL option that could be the problem as well, i've noticed that sometimes when i do that ther is pause's just like you described so now i just encode to NTSC.
Just a thought but worth checking.I Have Always Been Here
Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H -
ill give her a go without any de-interlacing..thanx for the tip..if that fails ill encode to ntsc
Rock On -
okies set it up so it didnt use interlace/deinterlace and im still getting pauses...any ideas?
Rock On -
actually, you should try using DVD2AVI... https://www.videohelp.com/sefy/?id=ClassicalGuide.htmlOriginally Posted by vamp1re
however, make sure your output is 25 fps and you have NOT checked interlaced and 3:2 pulldown...those 2 should NOT be checked...
otherwise, in TMPGEnc under advanced settings, you can try reversing the field order....
i'm also assuming you selected the correct aspect ratio for a PAL source. -
well...does the same problem occur on PC???
also, does your dvd player even support SVCDs??? find out here: https://www.videohelp.com/dvdplayers -
what brand/model is your dvd player...perhaps, it doesn't support SVCDsOriginally Posted by vamp1re
nah it definatly supports em big letters on front SVCD
its an LG DV5942P model..Rock On -
well, could be your dvd player is picky about the media...
test your SVCD on another dvd player......
btw, what's the max bitrate you're using???
also, try burning max at 4x... and burn as "track-at-once" rather than "disc-at-once" -
it is definitely a strong chance it's your DVD Player. Just because a DVD Player says it plays "SVCD" doesn't mean it's good at playing them. And just because a DVD Player doesn't specify it supports SVCD, doesn't mean it doesn't.
I had a Popular Sony DVD PLAYER the NS315 or something..and it jittered every 10-30 seconds just like your player is. It also occasionally hard locked while playing SVCD's. I did hours worth of research on this site and found out that one of the most versatile DVD players on the market is the Philips 724...I returned the Sony, purchased the Philips and NEVER had another issue with an SVCD like that again.
I would check your SVCD's on a friend or family members DVD player...as well as your DVD ROM. -
sorry shoulda mentioned that b4 same thing happens on my bros dvd and my mothers dvd all different brands
Rock On -
you sure???Originally Posted by vamp1re
i'm referring to MAX bitrate, not AVG bitrate....AVG bitrate may change, depending on the length of the movie, but MAX bitrate shouldn't...
do you not know what bitrates DVD2SVCD sets?? can you not take a look first??
the reason i'm asking this is because certain dvd players have hard time if bitrate gets too high....of course, it varies from one player to the next...but, it could be a possibility....
again, i'm referring to MAX, not AVG bitrate. -
hrm.....that seems to be correct...
ok..this is just for testing purposes...because i seriously dunno exactly what's the problem..since you've tested on various media and dvd players...
might wanna test on CD-RW...again..purely a test
anywayz, set
max bitrate = 2200 kbit/s
max avg. bitrate = 2000 kbit/s
min bitrate = 1000 kbit/s
again, just a test...but i've just made the bitrates less extreme...decreased the range b/w min and max bitrates... -
try 2 things...they're separate....
1) lower the bitrate even more, but still use VBR
2) keep the same bitrate, but switch to CBR -
ah okies..i had it set to CQ
what do u guys suggest i have it set too?Rock On -
more as a test -- set it to 1700 CBR and see if it plays smoothly ...
if it does or better than before -- its likely your player and / or media -
ok with the rate control mode set to
CBR and max avergae bitrate set at 2230
walla no more pauses..
*EDIT* spoke too soon
3cd svcd first 2 played fine last one paused.Rock On
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
