Hello,
I've been creating vcd's for quite a while now with very few probs but my films where on 2 or more discs, as I had some spare cash I bought a dvd rewriter so I could put my two disc films on one disc. All my files are 700mb or less but when I convert/render them using ulead movie factory or ulead dvd dvd maker the files suddenly become over the 4.4gb limit for a dvd-r. How can I convert my files to a dvd compliant format so they fit onto a single dvd-r?
I've tried tmpgenc but I havent got the dvd plugin so I cant use that, any suggestions would be appreciated!
DVD specs actually support VCD specs (resolution, etc...)
the only thing that's different is that you would need to upsample your audio from 44.1 Khz (VCD) to 48 Khz (DVD)...
in this case, you will NOT need to re-encode or convert.....you can author the VCD directly onto the DVD, to make a VCD-DVD...which should be fully compliant.... i would do a test first to make sure your dvd player is fine with it...but since a VCD-DVD is fully compliant DVD, there shouldn't be any problems...
btw, the good news if you take this route is you can fit 450 min. of VCD onto 1 DVD.
guide: https://www.videohelp.com/vcddvdr.htm -
thanks for that, I used the guide on here somewhere to convert the audio and hey presto! I used ulead to convert the file into a vcd file and then use movie factory to convert the audio and burn and it played fine on my dvd player!
Suggestion needed from DVD to HD
By onlygk in forum Newbie / General discussionsReplies: 4Last Post: 20th Nov 2010, 06:44 -
Dvd hacks needed
By poisonivy4 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Jun 2010, 11:38 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 13:27 -
Authored DVD exceeds DVD spec bitrate - advice needed.
By outerspacerace in forum Authoring (DVD)Replies: 27Last Post: 14th Jun 2008, 23:23 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
