    Dec 2000
    Bumblepluck, NY
    If one 80min CDR can only hole 80 min of VCD, how come commercially available VCDs fit entire movies on 1 VCD?
  2. do a search..I believe this has been tossed around several times..it because usually they lower the overall bitrate of the movie.
  3. those commercial vcd's may contain 1.3 gig
    Don't ask me how they do it but
    I'm still figuring out how to get 1.3 gig on a 80 min cd
    and can still be read by a vcd player
    Something to do with packetwriting
  4. HI
    It can fit via tow method :
    AUTOMATIC VIBRATE up to 1150k
    using TMPGENC ... access to my site , download the TMPGENC
    template and you will get a 90 minutes that can fit on a 74 regular cd .
    http://www.GEOCITIES.COM/GOLDENAXE4000
    or ... to switch the vibrate to 650K and run it
    to burn suck movie you will need a NERO 5.540 program .
    Oct 2000
    Prescott Valley, AZ, US
    VideoCDs are a different animal from typical "data" CDs. A true whitebook spec VCD can hold up to 74 minutes of video, regardless of how big the actual .dat files are.
    The only films that I've seen that are on only 1 disc (true VCD discs) are "adult" films.... well, not that I've actually "watched" any... but that's what the labels say.
    Most films require at least 2 discs. I have "King of Kings", and it is on 3.
    (edit)
    Oh, almost forgot. Straight DVD -> VCD rips look absolutely awesome using Smartripper -> DVD2AVI -> TMPEGENC route. But that will result in 2 discs per movie. I used sefy's SxVCD template for TMPEGENC and was able to fit all of "Army of Darkness" on a single disc. Playback quality was significantly reduced, and I wouldn't do it again unless there was a need to, but it can be done.
    <font size=-1>[ This Message was edited by: sracer on 2001-10-03 06:07:10 ]</font>
  6. i rather have a great movie on a 2 disc cd with good quality than a great movie on a 1 disc with shitty quality..
    wow, you have 70c and I dun mind changing the cd in my dvd
