I have a couple video's I've downloaded. They are all captures from a tv tuner card I would imagine.
Problem is that most of them are corrupted. They are in AVI format and playing them with BSplayer (which is the only player that will even play them) it says the vid. is corrupted but will play the vid untilll the point of corruption.
Does anyone know a program that will fix corrupted but in-tact video's.
thanks in advance
What... do what??
Mycophiles,
It depends really on what flavour of avi they are.
If you're not sure, use GSpot - it'll tell you.
I'd assume they're DivX of some sort - so try DivFix.
Also, you could try VirtualDub (Video->Scan Video Stream for Errors).
You'll find all of these free apps in the tools section on this site.
cheers,
mcdruid.
WebCam Video corrupted
By igbyslocumb in forum RestorationReplies: 3Last Post: 24th Oct 2011, 21:58 -
Video Becomes corrupted in After Effects
By Foristality in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2011, 05:18 -
Recovering corrupted mini-dv video
By bobogs in forum RestorationReplies: 8Last Post: 16th Aug 2011, 10:45 -
corrupted video file
By stikolyz in forum Video ConversionReplies: 5Last Post: 24th Jan 2010, 03:14 -
Corrupted video
By Faffnir in forum RestorationReplies: 7Last Post: 22nd Jun 2007, 16:28
