Hi all,
I imported subpicture as title in the subtitle editor. The file is in JPG format. The half right of the subpicture is cropped.
Does someone know the reason?
Shaul
Hmmmmm... In my experience, you were supposed to have the pic size 720x480, but I've gotten a similar problem with Maestro. I ended up using Photoshop to make the original menu item 92% of its original size and filled the rest with white or black to deal with the "Safe Action Area" problem (eg, when the TV does overscan adjustments on your DVD). Good luck!
thanks
what is more enraging is that I reduced the file to 207x97, 13kb. and whenever I try to use the navigation simulator the program is failed, but
without the subpicture the navigation simulator works well.
how can I overcome it?
thanks -
weird -- i would suggest re-installing maestro and dongle drivers .. make sure you have the latest version released ...
reinstall the cinemaster drivers also ..
Subpicture highlights look jagged on TV
By Henkie in forum Authoring (DVD)Replies: 9Last Post: 10th Feb 2014, 13:08 -
Subpicture Colour Changes
By sambat in forum SubtitleReplies: 2Last Post: 1st Apr 2009, 19:54 -
How can I replace one subpicture with another?
By doctorjellybean in forum Authoring (DVD)Replies: 2Last Post: 27th Mar 2009, 07:59 -
simultaneous display of 2 subpicture streams?
By Radish in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2009, 02:31 -
How to remove subpicture from DVD
By Scenik in forum DVD RippingReplies: 3Last Post: 9th Mar 2008, 15:14
