What do you suggest as a good MAC capture card?
Forgive my ignorance if the PC cards work on Macs too, but I'm under the impression it's not as easy as a driver change.
My friend has a Matrox RTmac, and it's great, but what are the other choices for Mac users? Both internal and external.
I think my next laptop will be an APPLE!![]()
I can always use VPC if I want to do something in Windows.
there is one by formac
www.formac.com
and one by el gato.
www.elgato.com
Those are the first two that come to mind. -
Go for a miroMotion DC30 plus.
I know they are no longer supported by Pinnacle but they are great cards and can capture at full DVD standard. They are frequently on eBay at good prices. Officially they do not work in OSX (OS9 only) but their are some Italians that have developed a great OSX driver. You can get it at
http://www.alfanet.it/squared5/
capture card for xbox 360/mac
By catsonheat in forum MacReplies: 5Last Post: 11th Oct 2011, 13:08 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
