I have made my first dvd and it looks great on the PC but no matter which dvd player I have put it in so far it plays back all flickery or the fields seem in correct or interlaced or wavey even ...hard to describe......this does not happen all the time only sometimes
Here are some specs
CCE 2.62 Pal 352x576
Video VBR 3 passes
2608 average
1000 min
9000 max
Audio Tmpgenc
Mpa 192kbs
I used DVD lab to author and burn have also created an image and used dvd decrypter to burn. As stated above it all plays fine on pc....
My thoughts on the matter are
Field order maybe incorrect i didn't use the correct field order. but if this is so when it be visible all the time
VBR when it is changing it is causing the problems
UDF mode....I will try nero 1.02
Or anything else some of you experts can think of
Results 1 to 13 of 13
How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
If you like Tekno download one of my tracks
www.users.bigpond.net.au/thefox149 -
Is it DVD-R OR DVD+R it will make a big difference ,also what kind of media are you using to write to,and finally is it a dvd/rw disc you have to specify to get our help...
It is DVD-r and this error occurs on both rw and-r
for rw it is a laser and for -r the highly prized ritek g04 x4
I believe it happens when the bitrate spikes....
so good media (except for the laser but I know it works fine on my player)How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
Have you tried authoring using a constant bitrate (CBR)? You should try that and see if the problem shows up.
I am in the middle of compiling some test files
Small Clips (idenitical) 80 seconds of video footage from my source
Note all encoding doen with CCe 2.62
Movie 1
VBR
Average 2608
Min 300
Max 9000
Theory ...maybe i didn't alllow enough spread between
Movie 2
VBR
Average 2608
Min 1000
Max 9000
Theory: This was my original specs and i wanna see if the problem occurs in small clips
Movie3
CBR
2608
Theory ...the error may occur when there are spkies in the bitrate....as the error seems to happen when there is movement of scene tranistions
Moive 4
VBR
Average 2608
min 300
max 5000
Theory max the spikes less to see what happens
Can anyone else see what i am doing wrongHow long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
try getting the audio in true dvd format before authoring
in my experience its always the audio that f###s up everything else
besweet rox
because of the number of codecs on a pc they will play nearly anything -
What makes you think it's the audio?
Here are the audio specs
48khz 192 mp2
it's all in sync...How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
I have not had a chance to test my files but does anybody have any suggestion??
Well i have tested the files and still no joy. Maybe it is the setting i am using in CCE. I changed the field order (this seemed to improve things a little) but in terms of max bitrate set to 9000 or 4500 no difference...The files were done with out audio so i am lost....What would happen if the gops are set to 1 instead of 15 (pal)
As it turns out it is a fualt in picvideo codec when going to DVD specs
Thanks to those that have helped me out over the last 3 weeks trying to solve this F#$king problemHow long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
Hi
I would like to know if you solved your peoblem? I also recorded some footage with PicVideo and converted to Mpeg2. I was going to author to DVD but as you state the PicVideo codec has some issues?
What did you do to resolve the problem? Recapture? Rencode?
Many thanks -
I had to recap using a differnet codec..huffyuy is good if you have the space if you have the hardrive space buti had to use morgan mjpeg ...but i am notusre of the setting to use werid stuff is happening to the endocded file ...deinterlace lines appearing I can't get nero 6 to read 800mb file as a standard svcd....aaarrgghh
my problem is back i am beggin to beleive that usiing any mjpeg codec going to dvd specs gives you prblems
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
MP4 player plays only MTV - HELP
By Lensmeister in forum Video ConversionReplies: 2Last Post: 25th Dec 2008, 17:35 -
I need a BD Player that plays AVCHD
By DSET in forum DVD & Blu-ray PlayersReplies: 14Last Post: 21st Dec 2008, 07:53 -
looking for a DVD player that plays it all
By gameroftheuk in forum Newbie / General discussionsReplies: 1Last Post: 6th Aug 2008, 22:45 -
Any video player that plays pretty much everything?
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 5Last Post: 13th Jun 2007, 19:12
