After I rip a dvd and encode to mpeg 1 with TMPEG, the audio sounds slighter slower or deeper than it does on the dvd or when the mpeg is on the computer. Anyone know what causes this or how to fix it? I'm using VCDEasy to add chapters and then I burn the bin file with Nero so I'm not sure where the problem is occurring.
somehow you are either changing your frame rate or its a bad sample rate conversion ..
What would happen to a subtitle of a movie in mkv format if I split it?
By SunKissUAE in forum SubtitleReplies: 1Last Post: 15th Jan 2012, 08:41 -
what would you do if this happen to you?
By Webster in forum Off topicReplies: 8Last Post: 6th May 2011, 13:23 -
Why does this happen? Resolution problem.
By bananadude in forum EditingReplies: 8Last Post: 14th Jun 2008, 03:47 -
----jerky motion----when did that happen?----
By ozne64 in forum Video ConversionReplies: 6Last Post: 15th Jan 2008, 06:00 -
What will happen to analog cable after the digital switch???
By yoda313 in forum Off topicReplies: 5Last Post: 12th Jun 2007, 19:32
