I used to get the Riteks (silver tops). I plan to buy some more but found some Riteks that have the logo. They are G03. Are these basically the same as the silver tops? Any problems with the logo type? thanks
Results 1 to 10 of 10
you mean the little white logo printed in the inner ring ?
they all come that way now ..
if you mean logo printed on disk , no idea as i use printable riteks .. but i would think they are the same quality .. -
hey BJ, just wondering, what printer do you use to print your disks?
it wont let me post a link but here it is:
http://www.allmediaoutlet.com/P-DVD-R-4.7-RITEK-LOGO.html -
I just received my 50 pack on Monday and burned about 10 disks so far. Yes they are the same as the normal Ritek G03, but the logo is pretty ugly. I'd recommend paying the extra money for silver tops unless you plan to stick labels on your DVD disks. The logo is VERY ugly and doesn't look good if you just label your DVDs with a marker or Sharpie.
Originally Posted by orbital517
just get the printable version -- plain white top thats easy to print on and mark on - same disk -
I'm actually using the silver topped G04's as I intend to buy the TDK thermal printer to label them with, and I think it works best on clear discs. They cost £1.25 each.
How did the fluke good DVD-Rs from Ritek & Prodisc come about?
By Bix in forum MediaReplies: 3Last Post: 19th Aug 2008, 16:23 -
Memorex DVD-DL "RITEK S04" PLEASE UPDATE the media section.
By Crazyj32 in forum MediaReplies: 12Last Post: 13th Nov 2007, 03:28 -
Office Depot brand dvd-r/ Ritek seconds?
By dnix71 in forum MediaReplies: 5Last Post: 31st May 2007, 20:15 -
Ritek set to mass produce rewritable BR & HD-DVD Discs
By akrako1 in forum Latest Video NewsReplies: 6Last Post: 24th May 2007, 10:24 -
Ritek Ridata DVD-R 4X G04 where or better?
By Illicious in forum MediaReplies: 8Last Post: 15th May 2007, 11:41
