Hi, I was using DVD decryptor for the first time today. Was working fine but got to about 55% done on my movie(Terminator 2) and then it said there was an I/O error and had a bunch of other info I didn't understand underneath it. I hit retry but no luck. I ran into this same issue with DVDXCOPY but I didn't like that software anyway.I'm getting frustrated b/c this is the fourth time I have tried to do this movie and I get the same error.
What should I do????
Results 1 to 15 of 15
If you are having the same problem with two different programs you may have a bum disc or a dirty disc. Try smart ripper. If you still have the same problem try different copy of T2. Are you ripping from your DVD drive or DVD-ROM drive?
Laddy, I am using the same drive it's both my dvd-rom and burner. I will give smartripper a try and if that doesn't work well I don't know what I'll do...
That may be your problem. I also had trouble ripping from my DVD drive. I had intended to use my DVD-ROM drive, but put the disc into my burner by mistake. I couldn't rip the damn film with DVD Decryptor no matter how much I tried. It kept getting stuck at the same point. I tried smart ripper and it worked fine. I have since been more careful about where I place my DVDs that I rip.
The only thing is that smart ripper is not in English if you want to be able to download it from their site. Guess I will just have to guess at what it's saying.
Posted: Aug 05, 2003 20:19
The only thing is that smart ripper is not in English -
Oh, ok I must have gone to the wrong place...sorry. I think I have it now.
well, T2 has alot of seamless branching...because both the theatrical and director's cut versions are in the same set of vobs...
i assume you're ripping in "file mode" and you have DISABLED multi-angle processing
also, play the movie with a software DVD player (i.e. winDVD or powerDVD) for a couple of minutes right before you're about to rip it. -
Ok, Laddy. I went to tools and it takes me to the site for smart ripper. From there I click download and it says do I live in the U.S. or not. I do and it won't let me downld. so I click No i don't and I can download it but it's in another language at first. No big deal.
Here's the new problem that came up...it says there is no ASPI driver available so smart ripper won't run. What should I do??? -
Check out the answer in this link. https://www.videohelp.com/forum/archive/t163695.html. See if that helps. Also I don't understand why your version of smartripper is not in English. I used the link in the tools section, said no when asked if I lived in the U.S., and the version I downloaded was in English!
the official version of windows XP aspi layer
and you don't need nero
Where can I get aspi32 drivers for Windows?
Nero's ASPI driver from Ahead Software.
For Windows NT4, Windows 2000 and Windows XP:
Download ftp://ftp6.nero.com/wnaspi32.dll. Copy wnaspi32.dll to the C:Windows System32 folder or to your application directory (no need for reboot).
For Windows 95/98/ME:
Download ftp://ftp6.nero.com/NeroASPIen.exe and read the readme.txt file.
More info can be found on Nero's download page.
Bart says: "This aspi manager from Nero is great, I can really recommend it"...
WHEN U COPY TO WINDOW SYSTEM 32 FOLDER. IF IT ASK U TO OVERWRITE THE OLD WNASPI32.DLL SAY YES -
Originally Posted by poopyhead
sounds like you don't have an aspi layer installed -
Originally Posted by vance43211
i've never had any aspi issues, so i'm not sure if it's because i don't have one installed or not...but neither smartripper nor dvddecryptor bitched about it... -
Window Xp don't have one already installed
like Windows 98 did (it was a cheap one though)
if you are using your dvd player to unlock smartripper
you don't have one
if you install adaptec latest version ASPI for XP
you don't have one, as
it was corrupted
there's a trick you can do with the old Window 98 version of adaptec vers. 4.6 (i think that's the versions name) ASPI layer
that's what bob w calls forced aspi
he knows more about that then i do however -
well...
i'm still using win98.
the latest dvddecryptor seems to work w/o having to play the movie first...
i only do so with an earlier version of smartripper that i have.
and, i don't remember installing any aspi
google search pages keeps erasing my search criteria -- [RESOLVED]
By vhelp in forum ComputerReplies: 0Last Post: 5th Mar 2011, 16:27 -
Problem with samsung dvd writer .. plz help!!
By jukaragz in forum DVD & Blu-ray WritersReplies: 7Last Post: 28th Sep 2010, 14:49 -
forum search cuts off @ November 2005?
By lordsmurf in forum FeedbackReplies: 2Last Post: 13th Nov 2009, 03:58 -
Search Excel Spredsheet Data in Vista Search
By mn072065 in forum ComputerReplies: 11Last Post: 29th May 2009, 00:26 -
Improve search function on forum
By cd090580 in forum FeedbackReplies: 0Last Post: 2nd Aug 2008, 09:59
